Help with choosing a softener system
Vish Gajendran
Grand Terrace,CA
My son moved to a new home in Grand terrace. 3 bed room, 2 1/2 baths home. Mostly it is one person. We go from Northern California every couple of months for a few days with the dog. We talked to Culligan and couple such, got pretty expensive quotes. Then came up on this site. We are looking for suggestions for water softener system and possible ROS for the kitchen. Also we need recommendation for a plumber to install. Thanks
Bannerman
Ontario, Canada
A report of the water conditions would be useful. If the water source is municipal, the town/city will typically post a water report on their web site. Many municipal reports will only indicate average water hardness from all sources whereas it is best to test hardness directly at the home where the softener is to be located.
If the source is a private well, then your son will need to have a water sample lab tested, which will include the hardness level.
Both National Labs http://www.ntllabs.com and Kar Labs https://www.karlabs.com are reputable, reasonably priced and highly recommended.
This site will typically recommend a softener system utilizing a Fleck or Clack control valve, paired with domestically produced tanks and resin. Proprietary equipment such as Culligan and Kinetico offer limited distributorship and service support so they are typically not recommended here.
Vish Gajendran
Grand Terrace,CA
It is Municipal water
Latest report is for 2016:
Chloride 28.7 ppm
Sulfate 51 ppm
Total Dissolved Solids (TDS) 382 ppm
Calcium 66 ppm
Total Hardness CA C03 214 ppm
Total Alkalinity 192 ppm
Bicarbonate 236 ppm
Magnesium 12.4 ppm
Potassium 3.1 ppm
Sodium 39.1 ppm
You want a softener with 1.5 cubic ft of 10% crosslinked resin with a 54x10 tank, or a 1 cubic ft.
