nico23
The house we bought last year is on a private well and currently has a small sediment whole house filter. However, this filter is not strong enough to keep the iron out of our water. After living here a year, our white toilets, sinks, and showers are stained brown, and the only water we can drink is from the fridge that has an additional filter (and tested no iron in it). Another technician said that our low pH is destroying our toilets but not our pipes as we have plastic pipes.
We have contacted three water filtration companies and three plumbers in our area, but we have gotten significantly different advice and prices. I'm hoping someone here can give us some trustworthy advice.
Here are the ranges of our two most recent water test results from the well head:
Here are the companies/plumbers we have called and their recommendations:
I know this is a lot, so here are my main questions:
- Total Iron: 2.1-3.4 ppm
- Ferric Iron: 2.1-3.3 ppm
- Ferrous Iron: 0-0.1 ppm
- pH: 6.3-6.4
- TDS: 30
- Alkalinity: 34-44 ppm
- Hardness: 1-1.8 gpg
- Copper: 0.1
- Sulphur/Chlorine/Nitrate/Nitrite: 0.0
- EasyWater: says we just need an ironshield iron filter; says it will get rid of iron and raise pH; says no need for a softener; says there's no salt so low maintenance
- Leaf Home Water Solutions: says we need a neutralizer 1.5 filtration system and a softener 1.0 filtration system; said no need for an iron filter (I'm assuming we would keep the current sediment filtration system in place?)
- Culligan: says we need a iron filter, a neutralizer, and 8" softener
- Plumber #1: says we need an air injection iron filter that will eliminate iron and raise pH (also recommended UV and reverse osmosis systems)
- Plumber #2: says we need an air injection iron filter that will eliminate iron and raise pH, but will then also need a water softener as eliminating the iron and raising the pH will make the water hard
- Plumber #3: says we need a Large CSI Sidekick Auto Backwashing Filtration System (didn't mention low pH or softener)
- What system do we need for the water results I shared? (e.g., iron filter, neutralizer, softener)
- Is there any quality compact system that would fit in a crawl space (or above a washer/dryer in a small mud room) so we don't have to buy a stackable washer/dryer, bury the system, or build a vertical shed?
- Are there any companies/brands you recommend?
