Charlie Bosco
Active Member
Here is all the detail I can provide.
Well water - Tested No Iron no bacteria Hardess was like 300
Tons of Hydrogen Sulfide which is why I added the Katalox to the system. That was added a few months ago and the Carbon Filter was just rebedded last month.
Water Treatment Water flow
Well
5 Micron Filter
Kinetico Water Softener ( I have a constant drip of ResCare)
Katalox AIO System
Catalytic Carbon
House
Today I noticed that if I left Chlorine based toilet cleaner in the bowl for 20 minutes it turned the water brown. I have done this in the past and have NEVER noticed this before.
So to test this.. I put treated water in one container and untreated right from the well in another
I dropped a small chlorine tablet into each one and water and stirred them up.. Waited a few minutes and bam! Turned brown! WTF is going on? See attached photo..
I decided to also grab the pool kit and test before and after PH and Alkalinity
Untreated
PH 7.2
Alkalinity 320
Treated
PH 7.6
Alkalinity 400
****EDIT****
Narrowed down to the Katalox filter. I took separate samples of water from directly after the Water Softener, And then directly after the Katalox. The Katalox water Turned Brown and the Water softener did not. soooooo
Can anyone tell me what is going on? I have also since added Salt with Iron Fighter. While I dont have iron, they use citric acid which I thought may keep my resin spotless since I have the rescare drip as well. Something being added/created in the water by the Katalox is causing a chemical reaction to the Chlorine
This is a disturbing situation..
Well
5 Micron Filter
Katalox AIO System
Catalytic Carbon
House
Untreated
PH 7.2
Alkalinity 320
Treated
PH 7.6
Alkalinity 400
****EDIT****
