Charlie Bosco
Active Member
So I'll start off with the fact I have been fighting Sulfur smell for a while and I believe I FINALLY have a handle on it. I inherited this system with the house I bought 3 years ago.
Initial Setup flowed this way.
Well Pump, Pressure Tank, Small GE House Filter with 5 micron, Kinetico Softener, another empty GE House Fiter cansister for adding chlorine pellets to flush Carbon Filter, 1.5CF Backwashing Catalytic Carbon filter, to house.
I have since added a 50 micron Spin down filter in front of the 5 micron filter before the water softener. This was just to make the small filter last longer.
I recently replaced my Carbon filter with a 1.5cf KL 2510 AIO system yesterday. It was a direct replacement since the all I had to do was slip the new filter into the existing bypass valve. Did 2 Backwash cycles and went live. Welp.. I made a stupid mistake and just pulled the drain line from the existing mechanical 2510 off the carbon filter. When I did the first backwash all I was able to pull was 5 gpm using a timed bucket fill. Did not know how to get more. After researching "STUMBLED" on the fact that the backwash GPM is regulated by that little effing DLFC washer. This is not really talked about much. I went and looked at the one that was included with the KL 2510 and it was 700 (7gpm) the one from the Carbon Filter was 500(5gpm) I swapped this morning and fired up another backwash and holy hell, it came out like crazy with a bunch more grey sediment..
Now that I have the Stink and the backwash resolved...I realized I have another issue.. The Kinetico.. It backwashes by usage and not a timer. And since it was installed BEFORE the original Carbon Filter it kicks into regen when it hits its preset limit. This most likely wreaked havoc on the Carbon Regen when they were both going at the same time. When I tried to backwash the KL filter this morning I heard that Softener kick into regen. I immediately bypassed it till the regen finished.
The big question here is can I assume the person who put the original setup together was an idiot? IT seems that the logical way to set this up is to pull it all apart and have it Flow this way..
Well Pump, Pressure Tank, 50 Micron Spin Down, remove GE filter and add a Big Blue 4.5"x20" 5 Micron Filter, Katalox AIO Filter, Water Softener.
Thoughts, comments??
