Help Please with New Sink Connection
rayc325
Louisiana
Hi All,
I am trying to hook up a new sink for a friend from church. She went from a double to a single sink. The problem is when I hooked up the disposal, the drain from it is almost inline with the stub out. Any suggestions on how this can be done? Thanks,
Ray
MKS
Illinois
The trap adapter normally goes on the end of the stub coming out of the wall. First picture.
Then use a p trap kit to connect the two.
A 1.5" P-trap is fine for a kitchen sink. The 2", which I almost never see here, would work too. That is what Sylvan would like on it.
It looks like you will need to cut some of that back and rebuild it from the wall.
How should Ray put a 1.5 inch trap adapter on his 2-inch ABS? Should he incorporate a 45?
MKS
Illinois
I have not done this exact install but that is were the fun comes in.
Rotate disposal. Add a 45 to the stub if needed. All good. Positive .
The pipe, rotated to show printing.
Sylvan
Still learning
New York
NYC old cold (1939 and 1968) sized kitchen waste as 2" now the brand new code is in effect for 11/2 waste my draining has sky rocketed because of the new construction
