Chuck B
sea-bee
Installed a Pearl Bath whirlpool tub with heater. Manufacturer requires 2 20-amp , 120v GFI protected dedicated circuits. In their instructions a #8 ground wire is to be bonded from pump motor to cold water copper pipe. However the electronic controller which the pump motor plugs into, and then you plug the controller into the GFI receptacle, malfunctions and is ruined. A service tech came out to verify this common occurrence. He installed a new electronic controller and advised me that the ground wire had to be eliminated as that caused the problem but I was still protected by the GFI. I called MAXX, the Canadian company that manufactures them and their "expert" concurred with the tech. Thoughts on safely operating it without the pipe ground and reliance on the GFI? Thanks.
