Flow inducer sleeve sizing for 40gph 4" SP
Evan Byrne
California
Hey all, I'm going to be installing a 35S20-8 SP pump and I'm trying to figure out what the appropriate flow inducer sleeve size would be. I see most threads on here people using a thin wall 4" PVC for a 4" pump, but I've also seen some mention of friction loss and larger sleeves for higher flow rates. This SP is going to be running continuously at ~40gph for hours on an irrigation system. Its going to be driven by a Grundfos RSI (solar) and I'd like to minimize friction loss and optimize flow as much as possible.
What size sleeve would you use for a 4" SP pump running 40gph?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Not use to seeing GPH, sorry. But that is less than 1 GPM so you need as small a shroud as you can get. Some pumps will not stay cool enough at less than 1 GPM.
Evan Byrne
California
Whoops. Yes, typo on the flow rate. I meant to say 40GPM. Gallons per minute. So with a 4" sleeve I shouldn't see any reduction in rated flow?
