Eddle6389
- Messages
- 10
- Reaction score
- 0
- Points
- 0
I finally got my sewage pump hooked and and I am having problems with the 2 inch Flotec check valve. I am getting small leaks on the upstream side of the check valve.
The valve is installed at a 45 degree angle. I am a bit confused about the instructions. The valve has flow arrows and also instructions that says "this end up for horizontal or vertical". Are you supposed to install it based on the flow arrows (which makes sense based on the positioning of the flapper) or on the "this end up for horizontal"?
Also - should the PVC connecting to the valve seat all the way against the rim of the valve?
Any ideas on how to fix the small leaks?
