Edward Smithe
Today I removed the KDF 55 sleeves from my twin tank econominder 9000.
One of the plastic necks that screws into the tank cracked so I decided to remove both of them. Getting the KDF 55 media holders off of the riser tube was extremely difficult. I had to shorten them by 1.5 inches.
I also had to put 1.5" pedestals under each tank.
Here's the problem, I manually initialed the regeneration for the tank, about 30 seconds into the regeneration the system started releasing huge amounts of resin as if the valves are opening in the reverse order.
I put the system in bypass, ran another manually initiated cycle only to have resin released from the other tank.
I'm perplexed and could use some guidance.
