David Rodecker
Greetings, I have a two stage house filter system that was inherited with the home. This is my second time replacing the filters with iSpring F4WGB22B (Sediment & Carbon block).
After performing the replacement and refastening, the second filter (carbon) leaks! In removing it, I noticed that this second filter does NOT have an o-ring. (unless I completely lost it in the removal).
I obtained an o-ring (Pentair Water 151122) which fit around the second lip of the filter casing joint.
I've applied some silicon grease. It lasted for about 3 minutes, then started profusely leaking.
I've attempted a second seal, this time with a good amount of silicon grease. Still leaking.
Doesn't appear to be any physical damage, crack or otherwise. Any suggestions?
