Hello,
Thank you for taking the time to read this. We have a 60+ year old house and an awesome little boy that hit $1/2 million of medical expenses before 2. So we have been getting good at DIY fixes, but this one has us stumped. Any thoughts or advice would be greatly appreciated.
The bottom of our tub appears to be black fiberglass. There is a white PVC pipe connected to the drain. The old drain was a bit rusty, so I replaced it about 5 years ago. I used a drain wrench and plumbers putty. All was good, until now. It started to drip not from the actual drain but from the edge of the grayish plastic part around the white PVC pipe. The pipe and pipe's connection are dry. The drip slowed and stopped before all the water was out of the tub. The overflow was not used and was dry. I am used to tub drains dripping from the pipe at the bottom, but this is different--I think?
I can try new putty and tightening it, but is this a sign of something else? I also don't want to over-tighten if that is not the solution.
I can try to caulk/jbweld/etc where the moisture comes from, but will that just cover up the problem (and/or make it worse).
What is the gray part even called? It is replaceable?
I have tried to upload a picture since my plumbing vocabulary is not very good. Thanks again!
