Md2020Drums
Hey all;
Mostly here for moral support, but I need advice too!
I’m in the trades, but I’m definitely NOT a plumber, so let’s get that out of the way. I work for a pretty big local outfit that does have plumbers and mechanical guys. I’m sure some of you may even work for them!
Anyway, my house was built in 58, and fortunately when I bought it, most of the stuff that needed to be done was done. Except for the DWV plumbing. The pressing issue is my laundry room.
I recently have had an issue with my laundry drain overflowing. I moved the discharge to the slop sink, but my curiosity got the best of me, so I opened up the walls and found work done incorrectly. The laundry standpipe and sink was all incorrectly redone at some point with CPVC. The standpipe itself was “wye’d” into the sink drain as you can see from the pictures. The vent standpipe is where it is, and my plan is to redo it all 2”. To keep this project as efficient as possible, I want to leave the galvanized vent and use a Fernco coupling to join the new waste plumbing to the existing vent.
So my questions for the pros are:
Is it acceptable to put a 90 degree fitting to go around the wall for the laundry discharge?
Is the vent standpipe going to come crashing down when I cut out the old tee’s?
The kitchen is tied into the same sewer line as the laundry, so my plan is to eventually do the kitchen as well. I believe my sewer line is cast iron. I’ve attached a photo of it. Will this accommodate a 2” pipe with a Fernco donut? It looks to me like it will, but I don’t want to risk without asking you guys first.
sorry about the essay! Look forward to hearing what you guys have to say
