Electric wire all 3
Geo422
Cin oh
My brother just called me. Here the problem,,,, new dishwasher ,he at work his wife decided she would install it.
She turned the power off ,disconnect the wiring , put all 3 wires together in 1 wire nut ,turned the electric back on ,
Her husband Joe came home found the wiring welding together, he cut the welded wires apart put a wire nut on each one.what damage could this cause
The breaker should have opened the circuit before the wires welded together.
A little knowledge can be dangerous! No knowledge can be disastrous!
A circuit breaker needs to see its current capacity exceeded, and often for a moment, before it trips. Now, that time is short, but it doesn't take long to weld the wires together! That current can momentarily exceed the rating when there's a direct short. If the current being drawn is very near the spec, if the circuit is on for a long time, it may also trip which is one reason why there's an 80% rule for some devices on the size of the wiring and protection circuits.
If you happen to get a screwdriver across some hot wires, it's not at all uncommon for the arc to take a chunk out of the shaft of the screwdriver prior to the breaker popping - steel melts at a higher temp than copper...wiring the hot and neutral together then closing the breaker can produce a huge surge prior to the breaker tripping. On a time scale, the time is very short, but think about spot welding something...only on for a moment.
