DWV for new bathroom questions
dlink
The pictures and drawing are what I am working with and what I need to do
Where the shower drain comes down from the floor the vent is roughly 22" behind as shown in the picture. The p trap would of course come down from the shower drain and will need to travel the opposite dirction of the vent.
The side view (last drawing) maybe shows more of what I am trying to do-The digital pic should have the drain at the end of the p trap facing toward you
thank You
dlink
Is there a code for the distance between san tee going to the shower and the street 90 run that goes to the drain?
Also what are my other option if the san tee and a street 90 does not fit in the space between the floor and the top of the cement wall?
dlink
The distance (Height) between the floor and the top of the cinder block is 7". A san tee and a street 90 is about 7 1/2 to 8" so it will not work. Any other things I can do that will meet Minnesota plumbing code
dlink
Is there any options that will adress my needs
dlink
How to Connect Shower drain to vent
The pictures and drawing shows what I am working with and what I am trying to acompolish
Where the shower drain comes down from the floor the vent is roughly 22" behind as shown in the picture. The p trap would of course come down from the shower drain and will need to travel the opposite direction of the vent. (The digital pic should have the drain at the end of the p trap facing toward you )
The side view shows what I am trying to do
Are there any other option that I can do it is the last part of my plumbing. It will need to meet Minnesota plumbing code
Thank You in advance :):confused:
dlink
Thanks for the info but let me make sure I have this right.
For the vent I use a 2" Wye combo?
Off of the combo I use a 45 but what is a strset? ( street 90?)
And what do you mean a Huts?
Sorry the words were a little hard to read
I do know that I have 14" in between the joist that I have to work with.
C NUMB
Plumbing Contractor
NPR, FL
www.ericsmithplumbing.com
use a street 2"45"(1/8 bend) and a regular 45"(1/8 bend) to make the turns or you can use 2" long turn 90", the combo is a wye and 1/8bend
Sorry for the scribble:)
Thats Hub although it looks like huts- it is what happens when I work 27 hours straight, I think I'm going to need some sleep here soon.
dlink
so does this look correct. Also where are you stating to place a hub?
dlink
gotcha.... I will try it out and update you..
and again thank you for your help ...
OK we are getting closer. I have laid out the dwv the way you show it is the above posting. My joist are 16 oc. a 2" combo and 2 45 or 2 long 90's come out to be 16", I need to fit this in a 14"wide area between the joist.
I need to loose 2" some where is there any fittings that I can use to do it and still me code. example can I use a reg. 90* elbow or a street elbow on at least one end? or both ?
thanks
dlink
I have laid out the dwv the way you show it is the above posting https://terrylove.com/forums/showpost.php?p=190358&postcount=52. My joist are 16 oc. a 2" combo and 2 45 or 2 long 90's come out to be 16", I need to fit this in a 14"wide area between the joist.
thanks
dlink
I have laid out the dwv the way you show it is the above posting. https://terrylove.com/forums/showpost.php?p=190358&postcount=52 My joist are 16 oc. a 2" combo and 2 45 or 2 long 90's come out to be 16", I need to fit this in a 14"wide area between the joist.
thanks
Anyone have a suggestion?
dlink
Can anyone provide a answer to my question regarding if I can use a lesser fitting that a long 90 or 2 45's to fit my space limitation.
https://terrylove.com/forums/show...8&postcount=52
I really appreicate the assistants
C NUMB
Plumbing Contractor
NPR, FL
I have not been around today but how bout this
You may need to fir the wall behind the shower to make the 2" pipe off the wye fit into the wall. The 7" you have has made it difficult. Place 2 st 45 out of the wye and either a long sweep 90 or 1 st 45 and regular 45 to complete the turn back to the trap for the shower
dlink
When I get a chance I will give it a shot. I really do appreciate the assistant you have provided. Your awsome
