So today I drained my electric hot water tank, and now three hours later I do not have any hot water (water flows thru the hot water faucets on the house, it's just cold). I followed these steps when I drained it:
1) Turned off power at the circuit breaker to the heater and shut off the water valve
2) Disconnected the hot water output on the top of the tank as I wasn't getting any water to come out of the drain valve, so I wanted to increase air pressure to help push the water out.
3) Once drained I reconnected the hot water output to the top of the tank and turned on the water valve.
4) Once the tank was completely full, I turned the breaker back on
5) About 30 mins later I turned on a hot water faucet and got lots of air for the first few mins, but then water pressure returned to normal (albeit cold)
Now three hours or so later, still no hot water. Tried turning the breaker on and off again and even tried the thermostat reset switch, but still no hot water. This is an older tank and I'm wondering if the heating elements crapped out, but any thoughts are appreciated!
