Dave&Carley
The tub has a sheet of osb (I'm guessing) covered in the fiberglass material and 6 high density foam blocks for legs (see photo)
The subfloor was mostly level, but I needed to shim under 4-5 blocks to get it fully level. I used the plastic shims and set them with high grade adhesive. Is this enough support or should I pack some mortar under it while I've got access from the back wall?
