Sewer Rat
I am doing a remodel on our master bath and intend to install a shower with a main shower head, hand shower on a slider, and two body sprays. I'm going to use all Delta components, mostly because I don't want the hassle of trying to match the look from piece to piece. Also, I'm under the impression that Delta makes decent quality stuff. That's the background, here's my confusion.
The valve trim I want to use is Delta's Monitor 17 series, P/N T17099, which Delta had listed as a reccomended valve trim for a multi-head system. The rough-in valve will be an R10000-unbxhf. I downloaded the specs for the valve trim and it is only rated at 1.75GPM at 80 PSI. The intended shower head and two body sprays add up to 4 GPM. The highest flow rate valve trim I could find (that we liked) is rated at 2GPM, still only 50% of what I need. Am I missing something here? Also the diverter valve will be an 11999 with an R11000 rough-in.
Thanks in advance for any suggestions.
