Lvrpl
I've got to put a new roman tub faucet in our master and was hoping for some advice. I'm trying to avoid soldering/sweating as I don't do it nearly enough to be reliable. To that end, I'd like to use PEX if it's a viable option. I intend to use a Delta faucet.
The current valve that's being replaced is hard piped straight to the valves (and there also aren't shut-off valves on the hot and cold copper lines coming in under the tub deck).
Any reason I couldn't/shouldn't put a valve on the hot and cold copper inlet pipes that are a compression connection, and have a PEX outlet (something like this)?
And then from there, I'd just just the PEX version of the Delta rough-in valve that goes with our faucet (as seen here).
Any reason this shouldn't or couldn't be done this way? Thanks for any help, I'm obviously new to this.
- Uses PEX crimp ring type connections
