Here is the valve:
The diverter portion on the bottom, as you can see from the color, is leaking. It leaks when the hose is turned on and it leaks into the wall, which shows up in the toilet area on the other side.
What valve is this and what part do I need to replace? It looks like it leaks where it threads into the valve and also around the part that 'turns'.
Can someone help me out?
