I have a 110' deep irrigation well with the pump set at approximately 100'. Records don't show where it's at, but the company that installed it thought it was around there. The static water level is 12' per the original well log. The well originally tested at 35gpm when originally drilled. The pump is 1.5hp. I don't know what flow rate it is. The pump company thought the pump is probably on PVC.
The pump cycles very often when doing things such as filling my pool, watering tomatoes... I'm pretty sure I need to install a Cycle Stop Valve. I currently have an approximately 40 gallon hydropneumatic pressure tank. I don't see any need to replace it.
One strange thing is that there is a 25gpm flow limiter upstream of the above ground check valve. The pump guy didn't know why it was there.
I'd plan on installing the CSV after the check valve but before the pressure tank right? Everything after the flow limiter is on pretty big pipe. I think it's 3" pipe.
I may run the irrigation out into a field, so I can probably have as much as 500' of irrigation line after the pump.
So, a couple of questions:
1) Will adding a CSV cause damaging pressures to the PVC pipe? I think I have a fairly high horsepower pump for the head I have.
2) What will that upstream pressure be?
3) Will the flow limiter cause any strangeness with the CSV? I think it would be similar to two CSV's in series which would limit differential pressures right? (maybe I'm thinking of that totally wrong).
4) Which model CSV should I use? I can see using up to the 25 gpm limit of the flow limiter if I hook up a small water reel sprinkler.
5) Someday when I replace the pump should I look at another 1.5hp motor or something smaller?
6) Anything else to think about?
