Correct pipe for well pressure tank with low 5.0 PH well water
WesM
MD
I am planning out the replacement of my slowly failing well pressure tank. My well water fluctuates in PH between 4.5 and 5.5. All of the brass fittings I have ever tried to use in my plumbing efforts fail in a few years. Currently everything in my house is CPVC except a small section of galvanized pipe connecting the current tank to the black PE well pipe, but I will replace the galvanized stuff because its rusted pretty badly too.
So what is the correct way to plumb in the pressure tank given the low PH water? Can I use CPVC for everything, including all of the pump pressure gauges, relief gauge and drain spigot mounting locations?
I also see there are stainless steel options, but I am reading its hard to get that to be leak free (stainless is tough stuff to tighten up properly?). I would be interested in hearing peoples opinions who have installed stainless tank tees.
WorthFlorida
Solutions
Orlando, 32828
This forum has many post on PEX for pressure tanks. Just search the topic.
