Converting from vertical jet pump to horizontal well pump, what is required.
Rjmiller
Morley michigan
Hi I have a 1h vertical jet pump on my well that's 68' deep. I am always having issues with the pump going bad it is a sta-rite pump. Can I convert it to a horizontal pump and what would be needed. Thanks in advance
Ginagina99
Houston Texas
Can you please elaborate on the subject of converting vertical well jet pump to horizontal? Ours just went out and then horizontal pumps are much cheaper.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You need a right angle casing adapter instead of the one facing up. Then you can attack a convertible type jet pump to the casing adapter. You can even connect using two hoses if both holes in the casing adapter are threaded.
