Constant Clog Kitchen Sink Plumbing...baffled
younggarfield
Los Angeles
Hi Plumbers,
Thank you for any insight you can offer
I have this kitchen sink where the horizonal pipe underneath is constantly clogged up with this sewage smelling debris despite hardly ever using the right side. At first I removed the horizontal pipe and cleaned it thinking it would fix the problem, but after about 3 months it would become clogged again. (I have done this several times already) I feel like the clog builds even when the sink isn't being used. After a while I would start to smell sewage smells coming up again.
Does anybody know why this is happening, perhaps there is a problem with the plumbing design? Is it possible that the sewage is coming through the drain pipe?
If it is a problem with plumbing design, which design do you suggest would be the best way to re-plumb this sink.
Thank you all in advance for your help
James Henry
Billings, Montana.
When you use the garbage disposal some sludge may be getting hung up on the horizontal tail piece. Get into the habit of rinsing the right side sink out after using the garbage disposal.
GReynolds929
Active Member
WA
The tee for the end out waste should have a baffle in it. If it doesn't then waste can flow into the horizontal line.
the horizontal is too low its below your trap arm . your waste was roughed in a little high and someone "tromboned" the p trap to allow it to connect. raise the tee as high as you can and cut a little off the tailpiece on the right side sink
I run the waste out to a tee.
Disposers work well for about eight years. Then the blades get dull and it outputs food matter that is too large. Either replace disposers on a timely basis, or find yourself pulling traps and snaking drains. Me, I prefer newer disposers and leave the snaking to my neighbors that don't know this stuff.
I run them like Terry as well only when trap is too high not sure if yours is but its close. but on a normal house I don't see them ever plumbed that way, can't say why but its never done on new homes in so Cal .
I will add that plumbing it like Terry's picture is common in other places though . never knew why we were different
Re-piping with a straight "discharge tube" instead of the black curved one as suggested by Terry and Jeff would be better than the idea below.
With the way you have it, I think you could improve over what you have to raise the tube that clogs higher than the exit into the wall. This would involve
  1. shortening the curved discharge tube
  2. shortening the tailpiece of the right bowl.
In addition, I would consider reducing the depth of the trap seal. This may or may not call for shortening the output of the baffle tee. Actually, reducing the trap seal may be a side effect of the other things.
In addition, I would consider reducing the depth of the trap. This may or may not call for shortening the output of the baffle tee. Dimension A or B in the following picture is the trap seal. That should be between 2 and 4 inches, and during your changes you might be able to get closer to the middle of those two numbers.
Ignore the words on these reversible p-trap pictures. The lower one is not really improper.
index.php
