You probably ended up with a better system than the $13k one. It would have been better to use brass, bronze, plastic, or copper piping instead of galvanized. I should have piped up earlier when you asked.
Once your tank gets more Should be fine. You will probably need two shielded couplings in addition to what you thought you would need. Those will add thickness. They could be on the jogged section to give clearance.
Follow?
Alternatively, leave the piping as is. Instead screw and glue so some 2x4 or 4x4 blocks to the sides of the existing studs. Attach your new mount into those blocks.Should be fine. You will probably need two shielded couplings in addition to what you thought you would need. Those will add thickness. They could be on the jogged section to give clearance.
Follow?
Follow?
Alternatively, leave the piping as is. Instead screw and glue so some 2x4 or 4x4 blocks to the sides of the existing studs. Attach your new mount into those blocks.reserve water, you might compare how things work with a 20 minute off-time rather than 10 minute. It might give almost as much water, and it might give a lot less water. That will depend on the characteristics of the well.
