Compression fitting removal tool?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TexasDIY, Jan 1, 2019.
  1. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    I'm replacing a faucet on the bathroom vanity and I can't get the compression nut out.
    Is there a tool I should be using?
    The water is turned off at main because the shut-off valves are being replaced.
  2. Terry
    Aug 17, 2004
    [​IMG]
    Most hardware stores have this style.
    [​IMG]
    And this one is very deluxe.
  4. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    Husband is on way to HD. Hoping they have one. (sure, start a project on New Year's Day they said...)
    Thank you.
  5. LLigetfa
    Feb 6, 2011
    Semi-Retired
    NW Ontario, Canada
    For the real stubborn ferrule, there is this.
  6. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    the tool we have is a Husky handle sleeve puller that removes stubborn compression rings..not working!
    any ideas?
  7. dj2
    dj2 In the Trades
    Aug 13, 2013
    California
    I've used a hacksaw blade to cut the sleeve BUT NOT THE PIPE.
    Take your time doing so, you don't want to touch the pipe nipple with the blade.
  8. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    We got the little mofo! took two of us crammed into a tiny cabinet wondering why two smart people were having such difficulties.
    we'll finish replacing valve, then do the faucet another day.
    Thank y'all for your help!
  9. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    We are now on to the cut off valve: we have measured the pipe and have the correct size, yet when we go to tighten nut (with compression ring inserted. the valve slips right of the pipe. Nothing to hang on to.
  10. LLigetfa
    Feb 6, 2011
    Semi-Retired
    NW Ontario, Canada
    Are you using a quality product with precise threads? On some poorly made products, the chrome flakes off the threads preventing it from being tightened as much as it should.
  11. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    We think the tool that pulled of the compression ring, made the pipe thinner at the point the new valve nut and ring attach.
    No water tonight - calling plumber in the morning.
    above our capabilities.
  12. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    YEs, I think so. Where the old compression ring was, the pipe is indented about a 1/4" around. so it's thinner there.
  13. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
  14. LLigetfa
    Feb 6, 2011
    Semi-Retired
    NW Ontario, Canada
    I think the ring cutter is a better tool and would not have distorted the pipe as the puller did.
    From the picture it looks like there is enough pipe sticking out to be able to shorten it about 1/2" to get the new ring back behind the distortion. Worst case you could use a two-piece escutcheon to slip behind the finished install.
  15. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    Yeah...should have used a ring cutter.
    Any suggestions on what to use to cut pipe?
  16. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    Would this work?
  17. LLigetfa
    Feb 6, 2011
    Semi-Retired
    NW Ontario, Canada
    A traditional pipe cutter would not run true on that distortion so you'd probably have to use a Dremel rotary tool with a skinny disk. An oscillating tool would work also.
  18. TexasDIY
    TexasDIY New Member
    Oct 28, 2018
    Texas
    Ohmygosh - we threw a hail mary with the linked pipe cutter. Cut just past the deformity and held our breath when placing new valve.
    It worked! We have water AND no need for a plumber.
    My FIL just passed in November and he was the one who insisted on fixing all the plumbing, so that we could actually do this (even though it took all day), is like a sweet nod to him.
    Thanks for all the help, guys! We appreciate ya!
  19. LLigetfa
    Feb 6, 2011
    Semi-Retired
    NW Ontario, Canada
    I wouldn't have guessed that you could cut it that far back. I figured some of the deformity would remain.
    Glad it worked out for you!
Similar Threads: Compression fitting
Plumbing Forum, Professional & DIY Advice New faucet, needs 3/8" compression fittings? Mar 18, 2020
Plumbing Forum, Professional & DIY Advice How close to the end can you cut copper stub-outs for a compression fitting? Nov 30, 2019
Plumbing Forum, Professional & DIY Advice Resolved: Help needed with compression fittings Nov 13, 2019
Plumbing Forum, Professional & DIY Advice Compression fittings weeping Oct 21, 2019
Plumbing Forum, Professional & DIY Advice Cone Seal for 3/8" Soft Compression Fitting on Flexible Water Supply Aug 2, 2019
