Clogged drain valve in water heater
Sassyav8r
Grapevine, TX
Hi guys-
First of all, thanks for all of the past advice and tips. You all are the best.
Secondly, I have a 6 gal. under sink point of use water heater that is
needing replacement. I can't seem to get it drained. I've opened the faucet, hooked up a hose, opened the t&p valve, banged on the side of the drain valve, turned the cold water back on to try and flush the clog, all done in various combinations.
I am at a loss. It is leaking now and I'd like to get it out before it
ruins my hardwood floors. Any suggestions? I'll attempt to load a
photo later.
Thanks in advance for your help.
Sas
SewerRatz
Illinois Licensed Plumber
Chicago, IL
www.a-archer.net
I have ran into this problem with the 6 gallon units, along with some of them where not even piped with a drain valve. Way I handled it was I opened the union and had my wet vac running the whole time till the tank was empty.
Sassyav8r
Grapevine, TX
Thanks for your reply. I've gotten some of the water out via the t & p valve but am wondering how much it would weigh if I tried to pull it out now. I figured there's probably 5 gal. left weighing approx 9 lbs each and the tank itself full of sediments likely weighing 15, so is 60 lbs. about right?
SewerRatz
Chicago, IL
www.a-archer.net
There abouts, I have tanken out full water heaters before. Not the easy way. One thing you could do is try to remove the drain valve. If it snaps off its no biggie, but again have a wet vac handy.
Redwood
Hi guys-
photo later.
Sas
Cut it out and carry it out full.
Be glad it's not an 80 gal. water heater.
Sassyav8r
Grapevine, TX
That's what I've decided to do if I can't drain it. I'm tired of messing
with the drain valve. I'm very glad it's not an 80 pounder. I'm just a
little 5'4" chick. :)
Redwood
Ummm Sassy,
I was talking about being glad it wasn't an 80 gallon water heater.
It would weigh about 850 Lbs. full!:eek:
Yours will weigh about 85 Lbs.
Sassyav8r
Grapevine, TX
LOL, yea, that's what I meant. That's what I get for typing and carrying on a conversation with someone else.
heater
I have NEVER drained a 6 gallon heater before removing it. Just cut or unfasten the pipes depending on whether it is a top or front connected model, the lift it out and let it drain outdoors.
Sassyav8r
Grapevine, TX
That's exactly what I ended up doing. It wasn't too heavy. Thanks for all the replies. Now I have to figure out what the plumber was thinking when he hooked it up.
Gary Swart
Yakima, WA
If you can be more specific about your comment about what the plumber was thinking when he hooked up the old heater, we might be able to offer some help.
heater
He was probably thinking, "Now all I have to do is get water into the heater and then out to the sinks and I am done." How he did would be unique to EVERY plumber and situation. Why are you asking.
