I have two 10" diameter, 1.5 cu ft tanks. The first is a backwashing carbon filter tank and the second is a 1.5 cu ft softener tank. My 1-year old Fleck 5810 filter valve failed after 1 year. Rather than doing a warranty swap, I'm having my service company swap out both valves (1.5 cu ft softener tank and 1.5 cubic ft carbon tank) with Clack WS1.25 valves. The carbon tank is before the softener tank.
My question is, to ensure proper regeneration of the softener resin and GAC filter media, what GPM DLFC buttons should be installed on the softener valve and which one should be installed on the filter valve? My guess is a 3.7 GPM on the softener and a 5.3 GPM on the carbon filter. Also, does a 10" diameter softener valve require the white Clack injector?
Anyway, my service guy is telling me that the WS1.25 requires a larger distributer tube than my old Fleck 5810. Is this true? I also see where the WS1.25 has an optional 1" drain line as opposed to the 3/4".
I would appreciate your thoughts.
