Thanks in advance for any suggestions.
1) Need to attach sewage pump to stack in basement. Stack elbows out to city about 3-4 feet from joists above.
1) At present there is only a 4x4x2 wye above the elbow (for kitchen sink upstairs).
2) I've added a sewage ejector Liberty 1 hp for new bath in basement with its own vent out the roof.
3) I initially thought about just adding a 4x4x4 wye to the stack for the pump but there is not enough length for that.
3) So my thinking is to replace the 4x4x2 wye with a 4x4x4x4 double wye, run the kitchen 2in to a Fernco 4 x 2 reducer at wye; and then run sewage pump 4 in to wye (double). Comments?
Also:
4) My plan is to place riser clamp support above the repair work, securing it to joist above. Can/should the riser clamp support be removed after repair is finished?
Again, many thanks for any help you can offer.
Also:
