Thanks friends.
I think I'll go at it with a "regular" rubber mallet next. The thread just above suggests dead blow. Might be a good excuse to get one of those as I don't yet have one! In response to other suggestions and comments: I have the head stripped down to the bottom half only and the tank strapped to a wall stud. I've never put anything like antisieze on the threads. I had this head off many (10+) years ago. I would have put pure silicone grease on the threads, if anything. Can't recall. Torque? 2x2 with 5/16 GRK lags dropped across either end. I stopped when one of the lags bent . . . . I'm pretty certain that the resin is toast, so I wonder if the resin leeched up into the threads and has them stuck. The only chemicals I have considered are Isopropyl (Noryl is apparently impervious to isopropyl) for the chance of resin lock and pure liquid silicone in case silicone grease has hardened for some reason. But in this situation how would you get any fluid to the threads anyway?
Before reach4 pointed me to the mallet, I was considering heating the neck with a hairdryer in case of gunk in the threads. Any opinions on using moderate heat?
I'll keep you posted. Again, I greatly appreciate your suggestions. k
