JoshRountree
I installed a CSV1A about a month ago.
The cut in pressure is set to 40 psi, the cut off pressure is set to 60 psi.
The working pressure for the CSV1A is around 55 psi, give or take what's using water.
If I use enough water to cause the pump to turn on, there is a buzzing or vibration heard/felt around the CSV1A working pressure (55psi). It goes away once it moves past 55 psi.
Is this normal? It's only felt/heard at the pressure tank. I was in the basement checking something else and heard it, we don't hear it in the shower or anywhere else.
