Good morning folks,
This question relates to the lifespan of a submersible well pump and what are the best pumps out there today as I am thinking about buying a new one to have on hand when the current one croaks.
To start, the old pump died 04/2011 and it was replaced a 4" Goulds Bruiser 7SB05422c, 2 wire, .5 HP, 230v, no control box. The Pressure tank and switch were replaced at the same time. The well is located on the bank of a spring-fed stream and is not all that deep....when the plumber removed the old pump, he said the pump was only down about 75 feet and that the well regenerated very quickly. We have iron in the water but not much in the way of sediment. Right now the Goulds pump is working fine but I am concerned that it will cr@p out when we least expect it. There are only three of us in the house so the pump is not being pushed to the limit, however, I am toying with the idea of buying a new, top-quality pump now as to have it on hand for the day when the Goulds pump croaks.
1. The current pump is 8.5 years old; what is a reasonable lifespan?
2. Given the specs above, what make of pump would you recommend? There is so much conflicting information out there....Goulds, Little Giant, Red Lion etc. I don't mind paying for the best.
Any advice would be appreciated, thanks.
