Smooky
That tells me that your problem is with the septic system.
What do you picture is causing the symptoms? With a clogged septic I would have expected either a backup into the shower or tub, or a wet spot in the yard. But all we get is bubbles from the toilet and the toilet not flushing. These symptoms sounds like somehow the vent line gets isolated, so there is air pressure in the pipe.That tells me that your problem is with the septic system.
Why doesn't the shower or tub back up?If your leach field is clogged, or the outlet from the tank to it (distribution box?), or the slope of the pipe going to the tank is wrong, or there's a partial clog getting to the tank, that line can fill up...nothing will work well when that happens unless it is higher than the clog and there's room in the pipe for stuff to get in there. Drain lines are not designed for pressure, and must flow easily via gravity to remain essentially empty so new stuff can get in.
Thank you all for your help...Going get someone to run a cameraIt's all about the order of which things are attached to the drain line. A shower dumps a bit over 2gpm, a toilet dumps 1.6g in seconds...a partial clog may drain fast enough for other things to still have room in the pipe...if the toilet is closer to the outlet, it could easily be full there. FWIW, a vent is required to prevent traps from being siphoned dry...most systems will drain just fine without one, maybe, too fast, and self-siphon the trap itself, but the vent is primarily to prevent other, downstream traps from being sucked dry as the waste passes by.
I will take the lid off today and see if I can tell where the water level isBefore I paid for that, I would look to see if the liquid level in the tank is rising up above the tank outlet.
I was sick today so I didn't make to digging it up..I know ours has 3 lids I haven't seen a wall in the middle ours don't have a filter..we been here 15 years the tank was here when we bought the place..There is usually a lid over the inlet and a lid over the outlet. There is a baffle wall in the middle of the tank. There is a very small lid over the baffle. If the tank was installed in the last 20 years or so there may be a filter of some sort on the outlet. Those filters can get clogged up and slow things down. You can usually just pull the filter out and hose it off. The guy that pumped it out may have cleaned it. He should have pumped both sides but sometimes they only pump the inlet side.
