Bubbles and slow draining kitchen sink
Inav
Ontario
Newbie here in Ontario.We renovating and due to new kitchen cabinets, we had to redo the plumbing under the sink.
The venting stack is about 2 to 3 feet from sink drain.
With the faucet fully open the sink slowly fills up and bubbles start coming up as it drains.
We thought it was leaves in the vent stack on the roof. So flushed that with a garden hose. We noticed that when the garden hose is running in the vent stack, we do not have the bubbles in the sink.
That seems to indicate that it is a venting issue. Seems like the "current" from the water coming down the venting stack is dragging the water from the sink with it. I guess the vent has a lower pressure with garden hose running in it???
Looking at the P-trap, I think that the right side should have been higher by an inch or two. Btw, we are using 1.5" and. Will this fix the issue I am having?
I have included a picture showing the current configuration.
I would think that when you run the dishwasher, that would push up into the sink.
I suspect a partial blockage where the drain line under the vent goes horizontal. That should have been a long sweep.
If you redo, maybe feed the dishwasher into a tail piece meant to receive a dishwasher output. Put a long sweep on that vertical to horizontal if practical.
Add a cleanout so that you could clean that elbow area.
I don't know why no suds when you are running water down the vent.
Inav
Ontario
What do you mean by "Put a long sweep on that vertical to horizontal if practical"?
In the picture attached, would that be #1 or #2?
Don't you think that #2 should be higher than #1 by maybe 2"?
Also by " bubbles", I mean air bubbles, not suds.
Inav
Ontario
#3 is 2 pieces of 45 degree elbow followed by about 6" horizontal run into the verticsl drain. #10 is connected to the vertical stack.
What should be the minimum horizontal run at #3?
Also, do you think that the height of #1 and #2 are ok?
OK. I mis-interpreted 3.
I am not a plumber. I hope somebody has a good prescription for you.
Highlander
Ontario
Possible blockages aside you have some s-trap/running-trap strangeness and the dishwasher is feeding into that backwards as well.
Out of the sink #11 should go down directly into a vertical tailpiece where the dishwasher will also connect to, end of tailpiece goes right into one end of the p-trap, exit of p-trap then goes horizontally to the san-t #5 (add a 22 or 45 elbow as needed to get things to lineup).
Connection at #10 and what it connects to could be suspect as well (is it a true vent or a stack that gets waste from, say, a bathroom above?).
Adding a clean out fitting above #5 would be wise while you're in there reworking it.
(not a plumber either)
My guess is that you wanted to maximize space under the sink, so you ran the drain back towards the wall before running it into the p-trap...not a great idea especially in a kitchen sink that can have food debris that might sit in that horizontal prior to the p-trap. It also slows the waste flow down. A straight shot to the p-trap, then run that outlet to the stack with the vent above, and it will probably work better.
