Hi y'all.
So I bought this house last year. I used information on this forum to repressurize my pressure tank as well as learn how to change out the pressure switch. Thanks for being a great resource.
I've got a strange issue now, and I am not sure where to start. My house is 2 stories and has a basement. When I flush the upstairs toilet or the main floor toilet, the bowl will fill all the way to the top, then it will drain really slow. It takes 30 seconds to a minute for all the water to go down, and when it does it goes all the way down to the top of the s-bend. One night, I flushed the main floor toilet and it acted just like this, but when it got to the top of the s-bend it gurgled quite a bit. The next morning though, they all flushed fine like there was no issue.
There's also a basement drain whose water level is much higher than normal but won't overflow. It has a little bit of foam on top of the water too, slight brown in color. There's also a toilet in the basement but it's 'shut down' because it has a bad flapper and nobody ever uses it so what's the point in having water turned on to it?
There's no odor anywhere in the house.
I posted on another forum about this and the one person that made the only reply simply said "sounds like a vent issue" and nothing more, and I can't get any more input.
I'm not sure what to do here. This house was built in 1850, the vertical part of the only vent stack in the house is iron, and goes from the basement all the way thru the second floor roof. The vertical part of the stack is metal (iron I think) and it has a cap. In the basement, there's a rubber coupling with 2 hose clamps that convert the metal over to PVC, then it has a 90 degree turn to go horizontal, which connects to a curved 90 degree adapter downwards (toward floor) to a 4 inch PVC main line, then that has a couple 90s and reconnects to a 4 inch metal line that goes into the basement floor and out to the septic tank.
I've not noticed any issue with sink drains, nor the washing machine, however I believe the washing machine has its own special drain directly to the sewer line, somewhere in the ground AFTER the vent pipe.
Help?
Pics upon request. Just ask and be specific.
Help?
