Derek Sutherland
I am building a shower that, among other fixtures, has 4 body sprays. I will be plumbing in a 3/4 loop for the sprayers to make sure I have ample water and pressure.
Question is does it matter where I start the loop? My design is I have a 24 inch door and on each side 18 inch walls at a 45 degree before it hits the main shower stall. Those 45 degree walls is where I'm putting the body sprays (2 on each wall total 4). So I will start the loop at the bottom of the one wall and then it has to make it's way all up and thru the top of the door and back down the other side and then back up through the top again and back down. Does it matter if I start the loop in the middle of the loop which would be above the door or doesn't matter?
