Best Toto for 11 in rough in
missnlove
Dallas, TX
I have ordered the Drake II but not sure it will work w/ 11 in rough in...any other suggestions?
Thanks so much!
missnlove
Gary Swart
Yakima, WA
Most Toto 12" toilets will actually fit an 11" rough-in. It does seem a bit strange that while we expect exact measures in almost everything, toilet rough-in measurements are not precise, but that's the way it is. I have 2 Toto toilets, both flanges are set at exactly 12", but the toilets have over 2" space behind the tank. I think you will be fine with the Drake II. My suggestion is, get the toilet and set it on the flange without a wax ring so if it is too tight, you won't have to clean off the wax.
I think you'll be okay, but Terry has answered this a bunch of times and you can probably find it with a little searching. The Drake verses the Drake II is a bit different with the Drake II (I think) having a bit less room behind than the Drake. You can fudge the toilet maybe 1/4" with the slop in the holes and not have any problems with the drain to gain that, if required.
Redwood
The Drake II only shows 13/16" clearance between the tank and the wall...
I would go with the Drake CST744S, CST744SG, CST744SB, CST744SD, CST744SDB, CST744SR which have 1 1/8" behind the tank.
