Bathroom rough in at camp
Justin1987
Pittsburgh Pa
Redoing my camp plumbing. I’ve done some plumbing before but not an awful lot. I just want to make sure I do it right the first time. My question is with the drain plumbing. Does this diagram look like the system would work well?
Ryan Miehm
Ontario
drain from the 3" toilet line to the kitchen sink connection would need to be 2" as it would act as a wet went for the toilet.
here in ontario, this would work as well, having the kitchen and bathroom sink connected together with a double fixture fitting.
Ryan Miehm
Ontario
and as long as there is nothing draining into the vertical 3" stack above the shower, the shower will not need its own vent. and shower drain should be 2"
I’m in Pennsylvania. I cannot connect the sink the way the diagram shows?
Not where you live.
Wet venting is for bathroom fixtures only.
The lav can wet vent the toilet if it's run with 2".
The kitchen sink comes in downstream of the toilet with it's own vent, which can tie in to the wc/lav vent at 42" above the floor.
Justin1987
Pittsburgh Pa
Not where you live.
So the above diagram would work? Just have 2 seperate wyes in the horizontal? Also would the kitchen and the bath sink both be 2"?
Justin1987
Pittsburgh Pa
The kitchen sink with 2" cleanout
The lav run with 2" because it wet vents the toilet.
Yes.
Thank you. Where would you suggest I put the clean outs? Should I put one on the closet flange if I have room? Also the wyes on the horizontal should be turned no more than 45 degrees? Also the santee on the top vent pipe should flow up or down? Thanks
The kitchen sink needs it's cleanout, if you install a 3" there it would also handle the toilet. Somewhere you need a 3" near the end of the run.
Vent santees are upside down.
Justin1987
Pittsburgh Pa
Vent santees are upside down.[/QUOTE
this is looking down at the bathroom floor. Would this work this way? I’d like to run the 2” drains through the 2x8 joists to keep the plumbing inside the framing. The sinks would turn up vertical inside the wall and The vents would go to the attic and connect to the stack so I don’t have to drill so many holes in the framing. Any more recommendations? I’m hoping to start this weekend. Thanks for all the help thus far.
