Kevin Boggs
Evening gentlemen and ladies. I recently added a utility sink, on the unfinished side of our basement, and just finished adding a bar sink, on the finished side. The house is newer construction and uses CPVC for all the supply lines. I branched off the 3/4 inch going to and coming from the hot water heater for the hot and cold lines. From there I installed quarter turn shut offs for both hot and cold, to limit the amount of time the house was without water. I continued with the 3/4 inch for about 8 feet until I reduced and split the lines to 1/2 inch using reducing tee connection to each sink fixture. The issue I am running into is that the pressure/flow coming out of the sink faucets are minimal at best. It would probably take over an hour to fill my utility sink. At first we though it was the utility sink faucet, since that came from our old house and had not been used for several years and new bar faucet is the same. Or that it was a clog in the supply lines, but the issue is with both the hot and cold. Neither faucet has regulators and I checked that the shut offs are completely open. Pressure for all other faucets in the house are still just fine and haven't changed. I'm thinking of replacing the 3/4 inch with 1/2 inch from the initial branch shut offs I originally installed to see if that would increase the pressure. Any ideas out there?
