Basement shower drain questions
Tom Hafemann
Simpsonville, SC
Hello all,
I am putting a bathroom in my basement. Everything was plumbed in when I bought my house except for the shower drain. So it has been "my pleasure" to tear up the concrete to put in the drain.
The main 3" drain wasn't exactly where I thought it was going to be, so it is going to be tight. I've included a diagram to show you what I am working with.
1. Do I need to vent the drain when it is this close to the main drain? There is a studor vent off the main stack about 6 feet away.
2. The shower drain will have slope and will interface with the main drain at about 2" above the bottom of the main drain. In other words, the shower drain will not be horizontal to the main drain. The shower drain will need to interface with the main drain at about a 45 degree angle. Should I be using a Wye or Sanitary T?
3. Since the space is close and I can not move the main pipe to completely glue in the Wye or T, do I glue in one end of the pipe and use a fernco the other end, or do I just use ferncos both ends?
TIA,
Tom
