Basement bathroom vent move under cement
Scubby
Hello,
This is my first post here but I have read a few of the other threads and the advice looks sound to me. I would like to install a shower in my basement bathroom and would also like to move some drain and vent pipes to locations closer to the main drain. In the picture you will see a tan colored vent pipe for the toilet, a main cast iron drain a clean-out and a smaller drain on the right. I would like to be able to move the tan vent pipe to a position closer to the wall and main cast iron drain. I would like to do the same with the smaller drain on the right. I will also need to add a drain for the shower which will be placed not far from where I was standing while taking the picture. I think the drain move and new drain addition should be pretty straight forward but my main question is can I have the vent pipe go horizontal under the cement to a position near the main drain before it goes up through the cement? Any help would be greatly appreciated.
Thanks.
In most places, Yes.
I would say that once you sawcut the slab, a plumber would be able to move many of the pipes over a bit and add the shower.
drain
From the look of the cleanout fitting, I doubt that you have enough depth under the concrete to do it. That fitting would normally mean that the mainline is right under the concrete.
Scubby
Thanks for the info
Thank you both for the info. I'll give it a try and see what happens.
