Auto Shut Off Tank Fill Valves?
Geek
San Francisco, CA
Why do plumbing professionals not use, recommend, or often even know about auto shut off fill valves? I've called numerous plumbers and supply shots and they don't even seem to know what I'm talking about.
I'm baffled. Even modern toilets use this crude flapper mechanism from the 1700s. Eventually, you'll get a slow leak, unhooked or stuck open flapper (e.g., kid or guest pulls handle too hard, unhooking the flapper or rotating the lever too high). If this happens unnoticed before a vacation, your toilet could be running for weeks, or worse, overflows. How many times do you see people with signs on their toilets ("flush gently", or "shake handle if water doesn't turn off")?
Solutions exist, but the plumbing industry doesn't seem to care. Is there a conflict of interest?
Fill valves that automatically shut off if there's too much constant flow exist. How can I find a plumber who will recommend and install one? Or is piston flush better way to go?
Are you referring to something like https://www.fluidmaster.com/pro-series-products/fill-valves/400ls-universal-fill-valve-leak-sentry/ Fluidmaster LEAK SENTRY? That will guard against a slow flapper leak, but it will not stop a flood. Or are you leading up to telling us about your product with sensor that shuts down water to the house?
Some cautious people turn off the water to the house before going on vacation. That guards against burst hoses too.
Some people unplug appliances they are not using.
Geek
San Francisco, CA
@Reach4, yes. There are a number of these. I have a few installed in my house. When a plumber sees one, they don't even know what it is. They won't support it. They want to remove it and put a dumb valve back in. WHY? I have to wonder if it's self-serving -- Is the plumbing industry really motivated to minimize your plumbing problems?
Not all are open to 'new' things...they have a way they do things, and are not willing to deal with anything different. There's something to keeping it simple, though. Yes, it's possible to get some major damage if something fails, but the things are really pretty reliable, and that's what insurance is for.
WJcandee
Wise One
New York, NY
The other reason people don't use them is that they are often balky and prissy. Korky made one (and may still make it), but it's wildly-unpopular. Fluidmaster makes one as well. And, as noted, there are the "whole house" shutoffs, which basically just interfere with your water usage without a lot of benefit. (How long is long-enough flow? If I and somebody else take overlapping 10-15 minute showers, the water will turn off. But if you set it to an hour of flow, your house is gonna be pretty-wet by the time it shuts off.) Turning off the main water when you're going away is still probably the most-reasonable solution.
Sylvan
Still learning
New York
If your going to shut your main valve as suggested you will want to shut off the gas fired boiler and gas fired water heater and make sure all traps have water in them prior just shutting the main and leaving
