Geek
Why do plumbing professionals not use, recommend, or often even know about auto shut off fill valves? I've called numerous plumbers and supply shots and they don't even seem to know what I'm talking about.
I'm baffled. Even modern toilets use this crude flapper mechanism from the 1700s. Eventually, you'll get a slow leak, unhooked or stuck open flapper (e.g., kid or guest pulls handle too hard, unhooking the flapper or rotating the lever too high). If this happens unnoticed before a vacation, your toilet could be running for weeks, or worse, overflows. How many times do you see people with signs on their toilets ("flush gently", or "shake handle if water doesn't turn off")?
Solutions exist, but the plumbing industry doesn't seem to care. Is there a conflict of interest?
Fill valves that automatically shut off if there's too much constant flow exist. How can I find a plumber who will recommend and install one? Or is piston flush better way to go?
