Any way to repair the off market brand kitchen faucets
JohnCT
Still learning..slowly
Northeast
Check the links I put above to the stem and cartridges that look like they will fit on amazon. Those off brands use off the shelf parts for the valving that is why they are able to sell them at lower prices. If you search you can find them on ebay, amazon, and cheapest cartridges are on Temu and Aliexpress but it takes 2 weeks to arrive from China so buy an extra one if you go that route.
I think at this point he's already replaced the fixture. I recommended back when he first posted to pull the cartridge and see if it was generic, but I don't think he did.
I would have bought a new one on Amazon, swapped the innards, and returned it.
John
Jsmallberries
Zephyrhills, Florida
No still leaking, it's slow enough of a leak and I had other more pressing stuff to deal with..
(Franke sells a few versions of a Kitchen faucet with a separate filter handle.) Price reduced to $414. yikes.... not going there
Just getting back to dealing with this problem, will check the links. I did take it apart, no place to buy parts locally.
Thanks for the advice, ordering new one and swapping out the parts sounds interesting
Jsmallberries
Based on my measurements, the Temu is slightly off. Just ordered this one on amazon.
I wonder if any heavy metals will leach out with the reverse osmosis softened water through this part??
Replacement Water Tap Cartridge Valve Core
Copper Faucet Ceramic Disc Gland Brass Bathroom Accessories Quarter
Turn 20 Teeth 1/2" Anticlockwise Rotation Single Thread 17mm Dia 42.5mm Length
Houptee
Monmouth County, NJ
Probably same material as the one that it came with.
The cartridge is most likely the 35mm one that seems to be the kitchen faucet size the Chinese faucets all use.
The 40mm cartridge seems to be for the Chinese shower valves.
I could be wrong so measure the diameter of the cartridge.
I have 3 kitchen faucets from Costco sold under their house brand Water Ridge and they use the 35mm blue cartridge. I got a 3 pack on Ebay for $12 last year and they fit perfectly. Now I see them cheaper on Temu but they can take 2 weeks to arrive.
Amazon they come quickly and you can send it back free if they don't fit but cost a little more.
Jsmallberries
Just installed, it appears slightly smaller, it works though.
Will test tonight to confirm slow drip is gone by leaving a bowl under it overnight.
It reversed direction for on and off though
Houptee
Monmouth County, NJ
You ordered the anticlockwise rotation, you need the clockwise rotation stem. If it says free returns you could send it back and get the correct one.
