Another PVC fitting question -- wall mount?
Mar3232
Indiana
thanks for the saddle tee answer yesterday but I also want to know if there is a fitting you can mount to a wall that will allow a drain pipe (1" or greater) to pass through a wall? it's an odd thing I'm doing where I need to drain something inside from time to time but would like to connect/disconnect outside with a temporary pipe/hose, yet have the inside drain permanent. I guess it would be like a 2 part sandwich you'd have to piece together.
thanks.
<out --- I (wall) I --- >in
(I are the wall sides)
wwhitney
Berkeley, CA
Some more information on what you are trying to do would be helpful. What is it you want that isn't achieved by just drilling the proper size hole through the wall and passing your drain pipe through it?
Cheers, Wayne
Mar3232
Indiana
Well, guess I could do that but just wanted some more mechanical stability and maybe a nicer look.
Be more informative -- less coy.
Going through an outside wall?
Drain pipe draining moonshine mash?
You are saying a drain pipe permanently runs to the wall? You probably would want a valve to cut off the flow. So what you really want is a concealed hose connection?
