thanks for the saddle tee answer yesterday but I also want to know if there is a fitting you can mount to a wall that will allow a drain pipe (1" or greater) to pass through a wall? it's an odd thing I'm doing where I need to drain something inside from time to time but would like to connect/disconnect outside with a temporary pipe/hose, yet have the inside drain permanent. I guess it would be like a 2 part sandwich you'd have to piece together.
thanks.
<out --- I (wall) I --- >in
(I are the wall sides)
thanks.
