American Standard Drain Alternatives
Singhsongs
Erie, PA
Hey everyone I am looking for a brass drain that would work with my American Standard Cambridge tub. I’ve been looking at the Gerber 41-813, I called Gerber and they said the 41-812 but I’m not so sure about the adjustment length. I also have considered Westbrass or Kingston drains as they are available at my hardware store, but I don’t know much about them. Has anyone found a drain that works with this that has a beehive or strainer drain with a trip lever? My fixtures are matte black and finding a drain has been very hard. Thanks.
https://gerber-gh.s3.amazonaws.com/gerberdocs/G00W1821_SS.pdf
WorthFlorida
Solutions
Orlando, 32828
Do you need a new trip lever or the overflow cover is shot? Is it the drain itself. Not sure what the problem is. All tub drains are essentially the same. As long as the pipe themselves are not leaking, most replacement drains or overflow covers will work. If the trip lever is broken, tou can remove it and replace the drain with a toe popper.
Singhsongs
Erie, PA
I’m installing a new tub and brass drain. Im not interested in anything other than the strainer trip lever style drain. I don’t want a toe tapper. I have a finger tap sink and I hate sticking my hand in there if I’m not cleaning it.
The Gerber 41-812 in chrome. I took this picture today.
Here it is with white trim.
New tub to go with new toilet.
Singhsongs
Erie, PA
This drain will work with the Cambridge Tub?
The water level on this tub is 14 inches. I’m not fluent in plumbing. I just don’t want water to escape my tub and go all over the place should I do the Gerber 41-812 or the Gerber 41-813? When I called Gerber they recommended both but he didn’t really seem sure. LOL.
Bathtubs (americanstandard-us.com)
thank you so much!!
I think Gerber drain above comes up at least 2" short.
Geberit makes a cable drain that adjusts the stopper from the overflow position.
The rotating handle snaps on.
