Bcarlson78248
My current 40 gallon gas water heater was installed in my basement in 1992, so its probably time for a replacement. I plan to do it as part of a larger renovation, so I have the opportunity to reconfigure things a little and look for higher efficiency.
Factors to consider
- I need a short water heater to match the existing flue pipe connection to the masonry chimney, but have space use a larger diameter water heater (e.g., go to a 50 gallon short).
- I don't think the existing gas connection would support a tankless, and it would require tearing up quite a bit of finished basement to upgrade the gas line.
- The utility room is large enough to provide the air volume needed for a Heat Pump water heater.
- Due to the other renovation changes, I could also switch from the existing metal flue into the chimney to a PVC flue and air intake that goes directly out the side wall.
- There is a floor drain almost right next to the water heater.
- I'm in the Washington DC area, so ground-water and air temps are cold, but not frigid.
The simplest replacement would be a new gas water heater, but the Energy Factor would be in the range of .58-.62. I've also looked at Heat Pump water heaters, Hybrid water heaters, and some gas models that advertise higher efficiency.
Any insight on reliable solutions that would work for a family of 2-4, and maybe gain some efficiency?
Thanks,
Bruce
Factors to consider
Thanks,
Bruce
