Advice on shower drain p-trap please >>
Erick Didonato
Pennsylvania
Trying to connect p-trap center of what’s supposed to be our future shower drain. Is this okay to go through the joist with a small straight nipple p trap from to then 90 towards waste drain pipe 90?
Tuttles Revenge
No. All your vents below the flood level must be drainage fittings and the vent for the shower must take off the invert/top of the pipe
Mr tee
Montana
You should be using a solvent weld trap rather than one with a union. 2" traps with unions are prone to leaking and you don't want that. If you can use a LS 1/4 bend rather than what you have it would be better.
Tuttles Revenge
X2.. I didn't see that union trap.
