I can't tell you how many times I've gone out to tighten a kitchen faucet that has loosened on a granite counter top. Often, it's because the installer that cut the hole drilled from the top, not accounting for the attachements for the faucet below the stone. For a faucet to remain secure, it needs to thread up to something solid.
Wood isn't solid.
Wood will compress and compress.
The fix is to cut a bigger hole in the wood support.
Here is what I find when I go out there. The faucet is snugged up to wood, which is too soft to hold the faucet tightly. You can cut it with a hole saw, but you need a pilot to keep the drill from skittering around and hurting yourself. Here I took a thin sheet of plywood, securing it to the underside with screws. I drilled a pilot hole down from the top, then transferred to the underside with my hole saw.
The end product looks like this.
I now have the faucet installed against the stone.
Wood isn't solid.
