SuperAcer99
Last week, the screen at the end of the distributor tube in my water softener broke sending resin through the pipes in the house. A plumber came out and cleared the lines, replaced the bypass boot and flushed out the resin the water heater. The plumber suggested that the PRV be replaced because he thought that the 85psi static measured with his gauge was too high and that might have contributed to the water softener problem. He replaced the 1" PRV and the PSI on his gauge measured 70PSI after placement. I now notice that water doesn't come out of the shower head with as much gusto, which is annoying. I went to my city's website and they said that the minimum PSI should be 50 and the maximum 120. It indicated that most people should receive 80psi and that if your pressure is above 80psi, then you are required to have a PRV installed.
Was the original 85psi all that bad? How can I safely increase the water pressure? Should I install an expansion tank on my water heater to compensate for the increase in water pressure?
